J.Lebel
- August 5, 2011
- Maine
- 1997 Mercury Mountaineer
I have a 1997 Mercury Mountaineer. While driving STRAIGHT, not turning...there is a horrible grinding/rubbing sound coming from the drivers side front tire area. I had the wheel bearing replaced on the passengers side within the last year, and the sound is similar but it is not while turning like it was with the wheel bearing needing replacement...so it is different. And that is the only answer I keep getting...I think it is something else...Also, when I got new tires put on a few months ago and the alignment was done they told me that on both front sides the cambers were at -1.6 degrees on the left and -1.2 on the right....and that I needed new cams to adjust front cambers? Well, I never got them...could this be the issue now? Because it sounds really, really bad....
