TheJackal
- August 11, 2007
- Mandeville, LA
- 1999 Explorer XL 2WD
As if those 2 things go together...
I've been reading a lot of information about Daytime Running Lights. I've seen a bit about there being a harness behind the driver's headlight with a jumper cap on it for vehicles that don't have the DRL option installed. I'd much rather have the Daytime Running Lights feature than to be turning on the headlights all the time. Not only does that use up the dash lights unnecessarily but I'm sure the day will come that I forget to shut the headlights off. I looked all around the harnesses going to the front driver's headlight but never found any harness that fits the description. Would anyone happen to know if there is an alternate location I can look for this harness at? I was going to order the DRL module but I want to find where it connects first as this is an electrical part that can't be returned, as I have to buy it from the dealer. According to the owner's manual the fuse for the DRL is also the fuse for the foglights. I can see the harnesses for the fog lights, which is cool because I plan to add those (but much later as it will cost me about $200).
While I was rolling around under there I noticed that the lower ball joints on the two front wheels need to be replaced. Does anyone have any suggestions on how to accomplish this? It seems straightforward enough but I can imagine being halfway through the process and having to deal with gorilla-fisted bolts and who knows what else. Anyone care to share their experience with this? I also plan to change the upper ones while I have the damn thing apart.
Oh, and BTW this is a '99 Explorer XL
