dual batteries | Ford Explorer Forums
dual batteries
Cowboys97x
Henderson, NC
97 XLT
Does anyone know where I could mount a second battery. I would much rather put the second battery under the hood if that is possible. And if anyone knows where then could they tell me the best way to attach the 2 batteries together to get the best out of both.
Any advice will help. Thanks
if im not mistaken.. wire them in series, and put it where you have room. u can put it in your trunk, but will need some heavy gauge wire to connect them.
Check out the link and scroll down till it say adding an auxiliary battery I hope this helps some.
2nd Battery
Yeah the thing with the battery location helps but I still need a pretty detailed description as to how to wire the batteries together. I wish the one that wrote it would have been more detailed by he wire the batterie to a switch how they charge etc...
Cowboys97x,
Also click the link in my signature to see an example of where i installed an extra battery....its in the "old ex audio" folder...pic # mvc 012s
D
You can wire them through a good marine isolator ( Guest makes good ones ) and charge two batterys from 1 alternator.
Just curious, but why do you want 2 batterys?
Good luck,
i meant parallel.. wire them in parallel like that link shows. i was thinking of something else..
I am putting my 2nd battery where the airbox used to be, and I am using the parts from http://www.hellroaring.com/
to combine/isolate them.
thanks that is really helpful. It was excactly what I was looking for. I want the batteries because I'm running speakers, winch, auxliary lights front and back, and an air compressor for shocks.
