Dumping 1995 Explorer Codes | Ford Explorer Forums
BOHICABOYZ
Houston, TX
1995 XLT & 2002 XLT
Greetings All, I am at a loss on why my Explorer will not dump the error codes. I followed the Tech Book on the How To's, but it did not work. Then I disconnected the battery, and that did not work! At A Loss!
Welcome to this forum! Disconnecting the battery will not cure what is causing the code. You now have to wait for the codes to reappear to find out what code numbers you have. What symptoms were you experiencing?
Where are you trying to pull the codes from? The 95 has a dummy OBDII port under the dash that is non-functional. 95s have OBDI/EECIV port under the hood.
I am using the port under the hood. I read the codes. I have corrected the problems, and follow the direction on errasing the codes, but the will not go away.
