DYNO numbers, Stock 08 STA | Ford Explorer Forums
stylin99
Gastonia, NC
'08 5.0 Coyote Adrenalin
I had the Adrenalin at Pro-Dyno for a base line to see what kind of numbers it was putting down, before it gets the supercharged 5.4 swap. Interesting stuff, although not surprising.
Max was 223 hp / 229 tq on a Dynojet in SAE correction.
Pretty pathetic !!
The most noticeable power killer was that Ford sets this thing up to run at 16:1 air/fuel ratio! Holy cow, that's lean! Most likely just for gas mileage numbers. These things would pickup a ton of power and torque just from a custom tune.
Pro-Dyno had tuned another ST on their dyno and just with a custom flash tune, picked up 40 lb/ft of torque, and similar hp.
These dyno runs are back to back. The second run was with the truck hot, so there was a decent power loss.
Are there tunes out yet for the Sport Trac?
Of course that is rear wheel horsepower too. I am sure Ford gives us the motor horsepower which is always more.
Yes there are custom tunes available (I recommend henson). Even with just an 89 tune I am very pleased. it pulls very hard through the mid-range.
Correct- dyno is measuring rear wheel, crank (published) HP is 292 for the V8, so we are at about ~ 20% driveline loss. Nothing too surprising in my opinion.
Justin starkey got 50rwhp and 50rwtq from my Trac in mid range with his tune! VMPTuning.com
My Current dyno numbers are in my sig!
