Tmoody69
- February 14, 2024
- Live oak florida
- 97 explorer
97 explorer 4d 2wd Ok so I’m 16 I’ve got semi decent mechanical knowledge but mostly chevys n older so I’m not good with eletrical so I got this trucks year ago he said it needed a fuse for the fuel pump well I replaced it and the fuel pump and the fuel filters it refused to run right and it was fuel related bc if I put starter fluid in the intake it would crank well I fought for months trying to figure it out I got it to crank run and drive 3 times but when I shut it off it wouldn’t crank again well the last time I was working on it (9 months ago) it completely lost power even with the battery charged so I just started working on it putting it into acc I would have power as soon as I tryed to turn it over it would make a loud click and completely loose power if I wiggled the hot wire power would come back and the same thing would happen I kept messing with it and it turned over finally well I seen the terminal was cracked so I replaced it and now when I turn it over it looses power then when I stop it comes back I’m at a loss and close to giving up can y’all please help me out I’m trying to get it to crank then fix the fuel problem from previous and I did pull apart the top and pull injectors they all worked
