jmedina
- November 14, 2022
- maracaibo
- EXPLORER XLT ELITE 2000
Hello everyone,
I just got this constant problem with my oxygen sensor, specifically Bank 1 Sensor 2.
I bought a scanner so I can check my Explorer anytime i need. And it worked just fine. Due to the fact that last month I was traveling to another state in my country and the check engine turned on,. I put the scanner in, and the main problem were the oxygen sensors.
1. Bank 2 Sensor: Poor Mixed
2. Bank 1 Sensor 2. High Voltage: 1.60+volts.
The first one was changed by me. The second one, I just changed it (today), put the scanner back on to measure, and it still showed me a voltage of 1.67 volts or more.
Another behavior is that when I put Stop or Neutral, it just goes to 0.02-0.01 volts. And when I put Drive or First, it goes to 1.6 volts, and it stays in that range.
Does anyone else have this issue? Apparently it is electrical, but where do I start? Any suggestions?
Thanks!
Thanks!
