LS431o28
- August 28, 2000
- Clearwater, Fl
- 91 Explorer XLT 4x4
Just curious if anyone has seen this problem? about 3 months ago my gas guage started acting up and then the engine started surging at idle and the lights surge at idle as well. now my battery warning light is on and the battery gauge shows around 10 or 11. Ive checked the battery with everything on when the engine is running and the battery itself shows 12 - 13 volts. so im not sure what i should tackle first. the alternator and hope its the voltage regulator or the computer or the ignition coil. the other thing is the chiltons says to check the instrument cluster voltage regulator yet it doesnt say where it is located or how to test it. well if anyone has had these problems or some of them could you please let me know what you did to remedy it.
Thanks
Thanks
