Electrical gremlins everywhere | Ford Explorer Forums
jones572
02 xls
Greetings all. First time on the forum. I've got a major weird situation with my 02 xls. The symptons(not always at the same time)are as follows:
power door locks cease functioning both with the door switch and the remotes.
radio doesn't turn off when the door is opened. has to be turned off manually.
interior light has to be turned off manually.
power door locks cycle through the automatic lock cycle numerous times.
Tonight I looked outside and the taillights and parking lights were on. the switch was off. no one in the car.
horn blows a short beep occasionally.
These are the things I can think of at the moment. If you have any, and I truly mean any, thoughts on this I would appreciate it.
Forgot to mention, I tried replacing the Accessory Delay Relay but that didn't do it. Thanks.:us:
Welcome aboard. Wish I could be of some help with your problem, but WOW, it sounds possessed. I agree that it sounds like a problem with the delayed accessories system. Maybe a bad ground on that system?
