LuvMyRig
- August 11, 2012
- Beaverton, Oregon
- 1992 Ford Explorer
:exp: My ride: 1992 Explorer 4.0L V6 pushrod with AC and 4WD
My engine shut off while I was driving, about two miles from home where I had left. It died without warning or sputtering, radio and lights still working. I tried to start it again, and the engine turned over but would not start. I got it towed home.
I figured that the problem was electrical because lack of fuel somewhere would have caused sputtering before dying. Sure enough, I checked the fuses, and Fuse #8 (30A) in the Power Distribution Box was blown. I replaced the fuse, and tried starting the engine. The engine started and ran for maybe ten seconds, and then died again. I checked the fuse that I just put in and it had blown.
So, apparently I am drawing too much current through this fuse. I checked the electrical schematic for my ride (Haynes, page 12-23). This fuse provides +12V to about two dozen different components through the EEC Power Relay: ICM, fuel pump relay control, fuel injectors, IAC valve, and the PCM, along with a few other components.
How do I start troubleshooting this fault with so many parts to check? Which parts should I check first and how do I check them? Also, where in the engine compartment is the EEC Power Relay? It is mentioned in my manual only in the schematic, and I am having a hard time finding it.
On a side note, I measured the resistance between the power cables after I disconnected them from the battery, and the meter read 0.00 ohms. I know that this has to be wrong because that would have blown my battery when it was connected, and the battery is fine. I tested the meter with known resistances, and got reasonable measurements, so what am I missing here?
