electrical problem | Ford Explorer Forums
electrical problem
macsexplorer
sydney,nsw
03 xlt
Need Help, all gauges not working like fuel,temp.,batt., &oil and also odometer
readout gone, power window not working, 4WD high & low not engaging. also when switch key to on position no indicators turning on except airbag indicator. motor still starting though & headlights ok. already check the book what fuse to check but i cant see anything that ralates to the problem. Thanks in Advance.
Fixed the problem, i disconnect the positive cable off battery for about 5 mins. then reconnect it again. put the key to on all indicators light up, me happy.
I'm having the same problems and tried your idea and it was a no go??????
