crossman
- August 24, 2001
- Buffalo, NY
- '91 Sport
A month or so ago, I posted a problem with my Explorer's voltage gauge needle climbing while driving on extended trips and the needle bouncing back and forth at idle. I thought that it was the alternator and so did others, so I put a new one in last weekend, but it didn't change anything. I did a voltage check at the lighter spot in the ashtray and it read 14.5 volts, which falls in between 14 and 15 volts, like my Haynes manual says. Is there anything else that could be causing this? I have also noticed that the needle bounces back and forth a lot more now and will do it just about all the time, no matter what RPMs I'm at. The dash and headlights also flicker most of the time like they do at low idle. Is there some other voltage regulator on my Ex. that might be bad or something else that could be bad? This is really starting to bug me and I don't want to end up frying my electrics because of it.
