ncsafetyman
- June 5, 2010
- nc
- 1995 exporer
1995 ford explorer 4.0 cranks won't start, died a few times, had to have towed home. changed computer, coil and crankshaft positioning sensor. Have power at coil / distributor plug, does not flash on the 3 negative terminals when cranking over. Does not show the 1.5 volts at the crankshaft p. sensor plug either. I am at wits end, and can't afford and garage bill, so need to get some help
The Iginition control module I have does not seem to look like the one showed in the manul. It is behind the battery, on the fender well. About 22 or so plugs, and only have power to one of those terminals
any help out there? Thanks so much
