tworx
- January 12, 2002
- Zephyrhills, Florida
- 93 XLT
Ok I removed my 4x4 shift motor and cleaned the brushes. I started to remove the switch cover (the one with the anti-tamper screws) with the new torx set I bought just for this and found that you need ones make of titanium since it killed my torx head so then I attempted it with the lock plyers and due to what I think is Loc-tite the head just broke off. At this point I did not attempt the other two (I don't have a tap and dye set). Put all back together and 4x4 now works. However when I stop, put into neutral push in the clutch and hit the 4x4 low button, the 4x4 high goese out and at that point I am in 2x again. Doese anyone know what could be causing this?
