Emergency brake won't light when set!!!! | Ford Explorer Forums
02XLS
The 51st state South Jersey
02 XLS
2002 Exploder XLS V6 - 74K miles
OK, I was driving to the inspection station to get my Explorer inspected and then I realized that the emergency brake light isn't working. Never friggggging fails. Everytime I take a car to the inspection station something goes wrong. Anyway the e-brake does light on start-up BUT when I set the e-brake "no light", sometimes a quick flicker of light. Any insight fellas...Is this a DIY repair???
Thx, 02XLS.......
probably a DIY , look for the switch down by the pedal, if there is one could be a loose wire,
Thx, I'll try to check it Sunday...anyone else have any insight???
02XLS
Agree with the fault being there at the switch. It could also be loose, mis-adjusted or have dirty contacts. All should be DIY fixes, especially with help from this forum.:thumbsup:
Okay, I found the switch right on the kick panel at the top of the lever. Everytime I touched the top portion the light would come on but go out when I reset the brake. I removed the switch and sprayed some wd-40 on it, reintstalled and walah! she's working again. What a simplistic looking part. Just some plastic, a screw and a metal dowel w/ a spring on it. Situation resolved, onto the inspection station on Tues.
Thx fellas...
02XLS
