Mikey in Miami
- March 4, 2022
- Miami, FL
- 1998 Ford Explorer Sport
The Instrument Cluster on a 1998 Explorer Sport has a short in it that blows the fuse when one of the wiring ports is connected, associated with the speedometer. I found one that was refurbished, tested working, all good...except upon closer examination of the two side-by-side I realized the one I got is for an automatic transmission, and mine is a manual. There's an adjustable cable attached that links the gear indicator to the an automatic shifter. The vehicle has over 200k miles on it and if the cluster will still work, albeit with an unused gear indicator I'm fine with that. But...when I look at the circuit panel on the back of the cluster I noticed a circuit and pathway on the potential replacement cluster that isn't on the original cluster I pulled from the truck. From where the pathway is positioned looks to be associated with the anti-theft light and circuitry in the cluster. But that's just by looks. Picture is attached, #1 is my old one, #2 is the replacement, I've circled where the extra circuit is on the picture.
Will this replacement instrument cluster work properly? I honestly don't care about the transmission indicator that's out of place on a manual, just as long as the rest of the functionality of the cluster will operate as it's supposed to without smoking a circuit or fuse. I'd have hooked it up to test it if it was just the gear indicator cable, but that extra circuit and pathway on the circuit board has me more cautious. Experience and expertise tips welcome.
