audiodude332001
- July 15, 2003
- Eau Claire,WI
- 2000 explorer 5.0
Hey, Tonight I started putting my truck back together after getting a new engine and tranny. I bolted the tranny to the engine, and the 4 bolts on the starter ring gear are alligned just great, but when I try to turn the crank to turn the gear so I can put the 4 nuts on, the crank wont turn. It will only turn if I loosen the engine to tranny bolts. I even tried cranking it with the spark plugs out so there wouldn't be so much compression in the cylinders, but it still wont turn. Any Ideas? I need to get this thing back together ASAP.
Thanks,
Andy
Thanks,
Andy
