Pitman Arm Installation Problems | Ford Explorer Forums
mhardy85
Calgary, AB
94 XLT
Sorry if this has been covered before, but I tried searching and couldn't find what I'm looking for.
My steering gear box was leaking, so I removed it and replaced the seals. I now have everything back in the truck except I can't get the pitman arm to go back on the output shaft. I tried centering the steering wheel and the tires, but it won't go together. The pitman arm is still connected to the tie rods if that matters. The only way I can get it together gives me right turns but nothing to the left, so I obviously had the arm lined up wrong. Is there an easy way to get this lined up properly? I have a Chilton manual but that doesn't give me any help here. I fought with it for hours this evening with no luck, now I'm stuck without a vehicle for work tomorrow. If anyone can give me some help that would be great.
You need to remove the pitman arm from the tie rod.. When its still connected it creates an additional force that will make trying to line up the splines on the steering gear with the pitman arm Very difficult.
Got it fixed up. Not paying attention, I put the steering gear together off center, so nothing was lining up for me. It's all working perfect now with no leaks whatsoever. So much nicer to drive!
