Engine Humming at Idle? | Ford Explorer Forums
JoeDirt
Harrisburg, PA
'96 Sport
Good day! I have a quick question about a rather annoying problem.
When my truck comes to a stop/sitting at idle, an audible humming noise sometimes can be heard coming from my engine. Most of the time it will go right away once I start in drive or reverse, but other times it takes a few minutes to stop on its own.
Any ideas? Is this a common problem with explorers?
Thanks,
JD
If it's a fairly loud moan that comes from the air filter, it's the IAC, idle air control valve.
Please use the search feature as there are countless threads on the IAC.
Alec, thanks...will do.
UT galveston? I spent a couple of years at UT austin and just saw another post from a guy in Austin. Small world, huh?
Good fishing and shrimp joints in galveston!
Thanks again:)
Well if you ever saw a good looking 96 Black Sport around that was me. It was s/c'ed in early 2001 and was lifted a bit later. I was in Austin on and off from mid 98 until the middle of 2002.
Probably passed you a few times. I was the white sport:D Yeah, put in some grad school time down there on the corner of san jacinto and dean keaton from 2000-2002. Now Im way up north again. I sure do miss TX!
