Engine idles rough and dies when cold. | Ford Explorer Forums
Ryan_289
AR
2005 Mountaineer
My 05 Mountainer will idle very rough when started up cold. It also will die sometime. It only does this on a cold start. I replaced the plugs and wires a month ago and that didnt help. (125000 miles it needed it done anyway). What could be causing my problem?
Ill try cleaning the sensors first. If it was a bad coil wouldnt it idle rough all the time?
Dirty Throttle body & MAF sensor maybe
