1mustangnut
- May 9, 2002
- Huntington, WV
- '00 Mountaineer 5.0
I have a 94 Explorer which has 140,000+ miles, which has been plagued by a persistant miss. The following parts have been replaced fuel pump, fuel pressure regulator, plugs, wires, egr valve, module on egr valve, 0xygen sensors, and head gaskets. I've tried cleaning the Mass Air sensor, upper intake, throttle body, and used several bottles of fuel injector cleaner. The code I keep getting is for low EGR flow. The light stays off at idle but once the engine is accelerated it comes on. I'm out of ideas and the Ford garage is not fixing the probem. Any one have suggetions???
