earnbud
- September 24, 2010
- New Port Richey, FL
- 96' Explorer 4X4
I need some help asap if possible , ill explain exactly what happened and im hoping someone can figure this problem out
I first got gas because i was almost completely on empty and i had to stop at the bank and i had someone else in the explorer so i left the engine on well on my way back i noticed the engine was off and he said the vehicle started shaking alot while it was in park and so he shut it off , well i went to go start it and nothing happened and so i was trying to figure out what it was , the battery is fine but it seems like the gas wasent getting to the engine , we checked the fuel pump relay because we heard no sound from the pump and we checked the fuse and the fuse was blown so we just swapped it out and tried it again and it blew another fuse so we tried a higher fuse a 30 amp and we tried starting the engine and we heard like double clicking near the fuse and found we blew the 30 amp one , but we also though it was the fuel filter at first so we took it out but when going to start it , no gas was coming out of the line like it should be with the filter off it should just pour out of the hose
So it seems like its almost a electrical issue , but we cant figure out why the gas is not coming out , almost like the fuel pump is off maybe due to electrical issue considering it blew out 3 fuses , so in the morning we are gonna look at the wires but i was hoping someone else might have had a similar issue and knows what to do to fix it
