Engine Start Up/Idle | Ford Explorer Forums
joelwc
2002 Sport Trac
Guys - would appreciate your thoughts here.
About two weeks ago, I went to the store in my 2002 Sport Trac (4.0 L). When I came back out the truck started, and then Immediately died. It would not re-start. I reset the fuel pump switch, pulled the fuse for the fuel pump, disconnected the battery, etc and would crank over but wouldn't fire. I went to call a cab, and after letting it set about 25 minutes, it started right back up, and ran fine.
Now I have noticed that when it starts when it is cold it acts like it wants to stall, to the point that I have to hit the gas to keep it running some times. Also very occasionally when I am driving I notice that when I come to a stop sometimes the idle dips but it has never cut out.
I have been reading about cleaning the Idle Air Control to fix those symptoms, which I did and there was no improvement.
I am wondering what my next steps should be. Should I replace the IAC valve? I dont want to spend the cash if it may be something else. Any other things to check?
Its been a great vehicle, about 130K on the odometer, and no real troubles.
Any thoughts would be really appreciated.
Joel
I am not sure if there is a how to up here, but I would try and find a way to test the iac. I wonder if it functioning correctly or getting stuck or something. I also might want to check the vac hoses. Cleaning the maf might not hurt either
check the hose to the evap purge solenoid, and the elbow under the passenger side of intake (check the link hawaii put above) never hurts to check for codes.
no CEL? check your battery cables/terminal for bad corrosion, look for any obvious vacum leaks on tubes and hoses, and try testing the manifold for gasket leaks.
Guys I replaced the PCV tubing. I did have a bit of a snafu. There is a small electrical connector that sits directly above the tube on the passenger side front that a wire pulled out of. I have no idea what it is. Any thoughts? Still starts/runs fine.
Edit: Its this connector (from another post)
<script src='http://imageshack.us/shareable/?i=pcvelbow1.jpg&s=221' type='text/javascript'></script><noscript></noscript>
