Exhaust Tip for Stock Exhaust?
Curse The Sky
2001 Sport Trac 4WD
Hi guys,
I'm hoping to find some kind of bolt-on exhaust tip for the stock exhaust. Ideally, I'd like something that takes the single pipe and splits it into two outlets for a nicer look. Most of what I've found seems like it'll hang way too far out from the side of the truck and just look silly.
Any suggestions? Bonus if they can be bought on Amazon. :D
Thanks!
any tip that is designed to fit that diameter pipe should work just fine. I believe it is 2 and a 1/4 inch pipe, might be 2 and a 1/2. should be able to measure it quite easily. you can always cut the stock pipe back a little to make room for your tip. best of luck
The biggest problem that I'm running into is the bend in the stock pipe before the straight section. That really limits the amount of pipe available to slip an exhaust tip over.
I'm not crazy about a single outlet on single exhaust, so I was hoping to find a tip with dual outlets that wouldn't stick out several inches from the fender. Most of what I've found so far seems like it's going to stick out so far that it'll look silly.
off to the muffle shop you go. I thinking about having mine come out from the side of the back bumper so its up out of the way. I will probably do that when I get a new muffler installed. A single black stack would look pretty bad ass also but I dont know how I could pull that off and still have my bed cover and it be water tight.
Top Bottom
