Explorer 04 mystery leak... | Ford Explorer Forums
Saik
2004 Ford Explorer XLT
I was cleaning my 04 Explorer today when I removed my car rugs. The bottom of the Driver Side carpet is soaking wet! I have no idea how it got wet. Only the driver side was wet. Now my car fogs up like crazy! Any tips on how to remove the water in my car?
Also another mystery leak. When i was driving in the rain a few weeks ago the top of my driver side roof started leaking from the moonroof control switch! The moonroof was completely closed. Another incident was when it started to leak on the sides of the driver side roof area. Where there is plastic. It's a mystery because I had it looked over by the Ford Dealer, and they could not find the source of the leak.
Now theres a huge puddle in my driver side bottom carpet :(
To remove water, a shop vac works great. :D
Have you had your windshield replaced recently? It might have a bad seal. You may have to try pulling the headliner out and checking around your moonroof too.
Another possibility, do you have a roof rack? Sometimes those leak.
I found the source of major flooring in my explorer. On the driver side, and passenger side I removed the carpet, and found under it the wires. It's literally underwater. What could cause this?
i'd check the sunroof drains they can clogged or disconnected. I though rubber hoses went down to the side 'B' pillar.
