Explorer 2004 v8 4.6L, limited, transmission flush | Ford Explorer Forums
Kenn08
Stockholm
Ford Explorer - 04 V8 4.6
Is there any guide to how to flush The transmission on my suv. Ive read a bit that its possible by The oil cooler. I have atf cleaner i wanna add first and new filter but how is The procedure done diy. Its Hard to get info from Sweden where I live.
Witch oil for transmission is The "best" aral, wolfhead...?
can’t help with the direct question....
For a true flush, I’d use a repair facility that has the machines designed to do it.
How many miles are on the trans and how often has the fluid been changed?
Had Ford flush the transmission at 100k.
It's the only work done but still going at 236K.
I too would advise having this done professionally.
Do NOT do this at home...3rd gens have a sealed transmission....take it to a shop to have it done. Do not do a flush if it has a ton of miles on it. My best recommendation is to have a shop that has experience with the 5R55S to do the flush and trans fluid change, or a Ford dealership.
A sealed trans, like yours, is a bit difficult to set the correct oil level on. It takes some experience to get it right. Like the suggestions above probably best to have a shop handle this. I paid $200 for that work here in Northern California
