Glen4X4
- June 5, 2007
- Lewistown, Pa
- 2000 XLS
Ok, I've trouble shot this myself since I know Explorer's pretty well by now. I did a transfer case swap on the 97 Explorer with a 96 Case and at first after the swap the test, it switched to hi, low and back to high. Now the truck does not even switch to high, the light on the dash does not even illuminate now. The 4wd lights do not flash like there is a problem, I've checked the fuse under the hood, I tried a quick GEM swap since I had a spare and still not working. I'm out of ideas at this point. I didn't however change the switch because I highly doubt that it is causing any issue because I disconnected the switch and started the truck and the 4wd lights still do not flash and they should when the switch is disconnected. So if anyone has any great ideas, throw them my way. And switching to a manual case in this truck is not the answer....
