Explorer Pro Comp ES9000's | Ford Explorer Forums
Diff Whack Daddy
And the Roll Over Posse! Under the Hood Moderator
Moderator Emeritus
Mount Vernon, WA
1st Gen XLT 4dr
Callsign
KG7VTT
I just installed a set of 24.5"(at full extension) Procomp ES9000's on the front. They are a gas charged shock and are comparable to a Rancho 9000 on the number 3 setting. So far, they are working great. The only problem that I have found so far is since the shock body has a larger diameter than the Superlift or Rancho shocks, at full droop, the radius arm puts a little dent in the bottom of the shock. I was told that this won't be a problem, since it is a dual wall shock and that is the outer wall of the shock. We'll see how it goes though.
