Explorer Sport 2002 Audio Help | Ford Explorer Forums
mig25
St. Louis area, Missouri USA
2002 Explorer Sport
Ok, here is the situation. I have a 2002 with the Pioneer 6 CD in dash changer. I have a Boom Box that I want to hook up to it. The boom box has an aplifier and two subwoofers and two tweeters. I was looking for the wiring diagram for that radio. I need to find out where to hook up the amp and the speaker. Please help ! thank you.
You can't just hook it up.. You are going to need to get a high input to low input convertor. This way you can splice into one of your rear speaker wires and use that to get a signal to your amp. The stock deck doesn't have a output for RCA cables. Other than that it should just be normal wiring ...
You could get a Auxilary input converter. They run about $70. It hooks into the the back of the HU where the 6 Disc changer hooks into. And then has another plug that you plug the Changer into. On the other end it has RCA inputs.
http://www.pie.net/aux_ford.htm
Whoops, just re-read your post. You need a output not input.
also called a line out converter. goto your local car audio place they will know what to give you.
