Explorers running lpg | Ford Explorer Forums
kernowman
Penzance Cornwall
'97 UK SPEC SOHC - LPG
For once, not a problem this time, as my four year old Romano SGI system is running reasonably well and saving me a fortune over running on petrol:) However, I hope some of you guys also running on lpg may be able to help me out. I want to do some fine tuning and can get the software for the Romano system and a serial lead to go from the lpg ECU to my laptop. I am stuck from there - cannot get any info on setup, readings etc. Willing to look at anything - possibly other systems use similar parameters. Prepared to beg, borrow, photocopy, rent or even buy any info on this system so I can get stuck into it. I gather when these systems are set up, it is done to a certain spec. for normal use and it is possible to tweak them more for either performance, or in my case, even better economy. Any help would be much appreciated.
Richard
Thanks, you have hit the items that I was going to buy. Got in touch with the seller last week and he informed me there are no instructions or user guide with this kit and he had no idea where I might get anything - hence my reason for asking.
Thanks for the help. Have already posted on http://www.lpgforum.co.uk/ with no luck, so have now posted on the other one. Still hopeful something may turn up. I am led to believe there are no PDF files on the disk. FES Autogas seem only to deal in OMVL systems.
Richard
oh sorry mate, thats why i used them as thats the system i have and they where so helpful i thought they may point you to someone who does yours.
