extended ABS wires? | Ford Explorer Forums
extended ABS wires?
the_don
park city, ut
'93 exploder limited 5spd
What is everyone doing about extending the ABS wires when doing a lift?
I have a superlift 5.5" lift and F150 coil seats and have had no issues with the length of my ABS wires even at full droop. I have them zip tied to my stainless steel extended brake lines, which are in turn clamped to the coils.
I do need even longer brake lines though. I have to keep my stock sway bar connected or else I have too much travel for my brake lines.
If it really comes down to it, the ABS lines can be unbolted from the bottom and unclipped from the top and it will give you more slack to work with.
I lifted mine around 5" as well, and didn't have a problem with the ABS wires either...
