extra lift what u think | Ford Explorer Forums
ExplorerX91
Yakima, WA
91 XL
as u all now the famous 2in coil spacers and aal or warrior shackles are very easy to install and are good for a price, i wanted to have more then just the soa and my 3in Bl so i wanted to this... would it be easier to install the coilspacers/aal before or after the SOA or at the same time or not at all, and also is it better to use the warrior shackles or AAL im sure i could find most of this info in past threads but there is way to many and way to much bs. thank you for ur time
If you do a SOA (spring over axle) it will give you 5.5" of rear lift. The Spacers only give an average of 1.5" lift. You will have to get the 6" front lift if you do the SOA. Then you can experiment with spacers, AAL and shackles to level your ride!
i know this... nvm fk this post
