ravinsaend
- November 22, 2010
- Where we lay our heads
- '92
Our '92 shows 3k+ RPM on startup, at all times idle, and ranges from there to just under 4k RPM. Just changed plugs, wires, IAC, air filter, oil/filter. It SOUNDS a lot better as well as running better, but the tach still shows the same. I'm not one hundred percent that the tach works properly. Before startup, when I turn the key to the on position, it jumps up to where it sits at idle. Aside from that it seems to work properly, though. Anyone have any ideas regarding this that will not involve randomly changing parts and hoping?
