Buckshot
- August 14, 2004
- Indianapolis, IN
- '97 XLT
So, I decided that I wanted to keep the interior of my X looking similar to factory but have added enough extras that I needed a switch panel.
These switches will separately control the following:
1. Brown wire mod (powered while car is on)
2. LED lights in PIAA 525's (power available anytime)
3. Fog lights in PIAA 525's (power while car is on)
4. High Beams in PIAA 525's (power while car is on)
5. Off Road PIAA 520's lights on roof (power while car is on)
and will also provide a location to hard wire my cellular phone charger/cradle and CB which will also both receive constant power available.
I didn't want the panel to look like an afterthought, and I didn't want to drill 1/2" switch holes into any existing dash panels (in case I screwed up, that gets expensive). After talking to a guy who creates custom stereo installs, I decided to use a plexiglass panel mounted to my center console in one of the "catch-everything-and-never-cleaned-out-holes" below the climate controls. Once the BACK of the plexiglass is painted black, the front looks glossy with similar depth to it as the factory radio displays.
Here is what is needed:
-$0.89 8x10 sheet of 1/8" clear plexiglass (better get 2-3)
-5x$4.19 Hella 20A 12V LED flush rocker switches (20amp for the brown wire mod, otherwise these could be had cheaper with lower ratings)
-electric sander
-13/16th's hole saw
-rotozip or dremel tool
-flat black spray paint
-time
will update with pics as soon as they are uploaded....
-electric sander
-13/16th's hole saw
-time
