Factory fog light wiring | Ford Explorer Forums
Tobashadow
Location
East Tenn
2002 Sport Trac
Callsign
K4TJL
I changed the radio dash panel to one with the dual fog light switch modded one and also corrected the previous owners double din radio mounting trim job aka he must have used a sawzal with a dull blade to trim it lol.
Mine did not come with fog lights which I plan on adding soon so I added the dual switch mod to have a factory look for it and have a second switch if I wanted to add additional lights later and it look factory.
The question is that mine seemed to have the correct four pin plug and wiring colors plugged into a dummy plug on the back of the factory trim panel but it does not light up the switch with headlights on which could be a blown bulb in it since it was used, but is there a possibility mine was wired for the option all the way to the lights? It doesn't really matter if it wasn't since I can wire them up but plug and play would sure make it nice.
If you find out the wiring diagram for the foglight switch would you post it as I am about to mod mine to control my roof mounted lightbar instead.
Thanks!
