Mitchs07explorer
- August 14, 2015
- Location
- Idaho
- Meridian, Idaho
- 97 XLT V8 AWD
07 XLT V6
okay I'm embarrassed to even be asking for help on this but I'm having a hard time getting the fan clutch bolt loose. I've been loaned the tools from O'Reilly's the 36mm fan wrench is loose but fit well enough I shouldn't round out the nut. Then they gave me another tool that's split at the end and has 4 holes drilled and hooks at the bottom. My belt was so worn that when I just tried using the wrench the pulley kept slipping. So I used the tool with the hooks to to hold the bolts on the pulley but they just bent out of place whenever I got enough leverage. So then I removed 2 bolts from the pulley so I can thread them through the tool and the pulley. I tried this morning again and I'm having a hell of a time getting the bolt to thread to the pulley given the lack of room. I managed to strip on the on the bolts already when I thought I had it in place. There a washers on the the bolts that are mostly a permanent piece, I took another bolt off the pulley and brought the two good ones to work with me and removed the washers so I could get that much more access to the threads to get it in tight. If this fails I'm going to buy a pipe wrench that uses a strap to hold the pulley or a 48 inch pipe wrench that will hold the pulley (if it fits) and give me leverage. Anyone have any advice for me?
