Thank you firephoenix, for your response. I finally decided it had left hand threads and with more torque than I thought necessary it came off.
Perhaps you might offer some more advice; I blew a head gasket at #6 cyl to the outside(not to the water jacket). If I have to get the head milled do I also have to get the undamaged head milled?
@James Meeks
Milling one head only will somewhat upset the "balance of the engine, as milling increases the Compression Ratio, thereby increasing slightly the pressure and power developed by that side of the engine. So, yes, milling only one head would be strongly discouraged.
However, if you hear the blown gasket's leakage, and the vehicle has not been driven too long with the leak present, what leads you to believe the head's surface would require resurfacing? Sounds like a possible selling of service scheme. If it were mine, I would have a guy having a "sniffer" check the space above the radiator coolant, while the engine is running, for unburned hydrocarbons, the presence of which indicates gasket leakage (or a minute crack) of combustion gases into the water jacket. A positive finding might indicate greater cause for alarm. OTOH, a combustion leak of any significance over-pressurizes the cooling system, and causes loss of coolant (and gas) via the radiator cap. The condition of the head gasket, inspected very carefully, can reveal much to add to the conclusions, as will the head (and block) surface.
Repairing the engine, unless done yourself (i.e., no labor cost) will likely come very close to the vehicle's market value. imp
