an alternative is to go to a hardware store (lowes or HD) and in the plumbing section get a adjustable metal spanner wrench. They are used for large nuts in toilet and sink fittings (boy that statement could be taken wrong). I have had good success with one from HD they are thin enough (about 3/8") to fit in the space and adjust from about 0" to 4".
once you have the adjustable jaws set to the right width you tighten the locking nut which locks the jaws in place, I have used it on multiple fans and various other large nuts. For a 9$ wrench it works quite well
I have that tool, but I didn't think of using it for this purpose. I use my 24" adjustable wrench on this. It gives me more leverage, and a better grip. Here's another idea if you want to be creative: http://www.explorerforum.com/forums/showpost.php?p=1807751&postcount=14. The tool I use is similar to the 24" one in the picture:
The reason I went to the adjustable lock wrench is because my 24" adjustable was just too wide to fit between the pulley and the fan clutch. And I think I had just finished putting a bathroom in for my mom so it was fresh in my mind. (although the word fresh may not be the best choice in this instance )
The Haynes manual says to, "Turn the drive hub nut counterclockwise to loosen." Wouldn't that be a right-handed (normal) thread? I'm a little confused.
There's not a lot of torque on the nut, but I believe the factory does use a small amount of loctite on the threads. I always use a large screwdriver wedged between the nut and one of the bolts on the pulley to keep it from spinning while getting it to break free. Once you break the loctite it pretty much free spins.
