gruss01
- August 12, 2009
- Toledoish, OH
- 2003 XLT 1998 XLT
I searched around and it seems this is a fairly common problem but it keeps getting worse in my 98 X. It used to be just when I was turning left into a parking place, then it started happening on the road I take to leave work, there is a big dip in the road right before the stop sign, now it seems to be doing on practically every stop when you get down to about 5mph or less. Shocks and brakes are new, Sensa trac's for shocks not the greatest but less than 8k on them I wouldnt think they'd be letting the tire loose contact with the road on minor stuff, plus the problem got much much worse after a couple trips up to Detroit driving on those craptacular roads
. so hopefully its just something loose???
I'm thinking a sensor or tone ring but if anyone has any pointers, pics, or resolved this issue themselves I would really appreciate it! I'll probably be yanking off the tires in a about an hour, hopefully I'll find it but I'm not the greatest with brake stuff, and I havent really had to work on the 98 a whole lot so I'm not real familiar with it either. Or is there a quick way to disable ABS? If nothing else I can run like that for a while until I figure it out, would be better than rear ending someone when the brakes start acting goofy!
Any help appreciated, thanks!!
Didnt see anything out of the ordinary so I just yanked the fuse for the ABS for now, I'd like to fix it correctly at some point though so anything to help let me know!
