NJExplorerFan
- May 29, 2009
- New Jersey
- 2015 Limited
Couple questions I had on the Gen III Explorers:
1. If the license plate bracket is missing, can you buy another one from Ford and put it into the factor holes? Or, is it easier to just drill 2 holes and put the plate on? Once the bracket is gone, can you replace? Is it even needed?
2. Is it the case that Ford did not provide a 5th lug nut lock special key? Or, did all the 17" wheel Explorers come with just 5 standard lug nuts and no special 5th lock nut?
3. Did Ford ever issue an official recall on the applique split on the rear tail gate? If it is fixed, what is replaced?
