Kamel
- October 9, 2008
- Orange Park, FL
- '95 Ford Ranger XLT 2.3L
I posted this same post on another forum, before realizing that forum looks totally dead. I apologize for posting in 2 places, not something I normally do so just wanted to mention that up front.
Alright, I have been working on this for quite some time now. Finally, I've decided to ask for help. Not like me, because I enjoy figuring things out on my own or without having to ask and bother others with my troubles. Anyway, here's what's going on.
1995 Ford Ranger XLT 2.3L 5speed
Throwing codes: p0135 & p0141 (heated o2 sensor heater circuit, both banks)
Only had it for about a year, not sure what prior owner has done to it (had codes when I got it)
I went ahead and replaced both o2 sensors, and they looked in pretty good shape -- they also broke free pretty easy, so I'm pretty sure they were new (ugh, wasted money sucks). Just to be sure that didn't fix it, I cleared my codes and they came back after a quick drive around the block.
I also checked fuse #20 in the cabin fuse box and it's fine. Also checked for voltage to both sides of the fuse with the key on, both good (I also used a test light to confirm... I once had an electrical problem that was reading good volts but not powering a test light so I always do this lol). I decided to try and test amperage draw on the fuse, and it ended up being 0 amps, so whatever it is doesn't draw much current or it's got a broke wire somewhere.
I couldn't determine any other fuses that the o2 sensors could be on, but I'm not sure if I'm looking at the right fuse. I've failed at finding a decent wiring diagram for my truck. I saw a few things on the net talking about checking a "light blue/orange cable" to the o2 sensor, but all I'm seeing is 2 white cables, a grey one, and a black one. I couldn't see the color of the wires coming from the harness of the vehicle itself all covered, but I'm going to try again soon.
Having said that, I have a couple of questions.
1) Even if it doesn't help me fix this issue, it'd be cool to find a decent wiring diagram if anyone knows where I can get one
2) Is fuse #20 (15A) in the cabin fuse box the correct fuse?
3) Should I be able to verify the o2 sensor heaters are getting power by turning the key in the on position then testing for voltage between the frame of the vehicle and each pin of the o2 sensor plug? How many of the pins are powered, just one?
4) How is the wiring routed for the o2 sensors? I see it going up and around the transmission, then I lose it
and finally...
5) Am I on the right track? Maybe you have a totally different idea, I'm open for suggestions!
Thanks a lot guys
and finally...
Thanks a lot guys
