Gettin a new Gasket set?
I believe the Felpro top end gaskets are identical to Fords... im not for sure. Jefe mentioned it before.
Ford Gaskets from what i understand are 'Vulcanized Aluminum' around the port openings, which makes them stronger then most aftermarket brands... Go for ford if you can, but again from what i understand Felpro is identical.
