- January 26, 2004
- Mechanicsville, Virginia
- 2004 Acura TL
If you are doing anything timing related or doing a leak down test; it's always important to have certain cylinders at TDC at certain times with certain valves open/closed. Now, a tip for find TDC is to remove the spark plug and stick a long screw driver in the spark plug hole and start to turn the motor over manually. Do NOT rotate via starter/electrically. Once the screw driver is coming up and starts to move slowly down again, you are around TDC. It's ok to spin/turn the engine in a normal operation condition direction, but do not rotate in opposite direction of normal op - unless it's a small amount. May cause valvetrain to bind.
-Drew
Ps: you could also do it the dial indicator way for TDC:
-Drew
