coliniscool
- February 15, 2005
- San Jose, CA
- 97 XLT
So i just had my 97 XLT diagnosed two weeks after i bought it. and the shocks need to be replaced, the drive belt is cracked (but my mechanic says that it probably won't break, but i should have it replaced), the general 100,000 mile services need to be done (plugs, differential service etc.) and the front differential might have a loose pinion OR a shotty wheel bearing from the sound i was getting from inside. so my question is, what should i get done in what order, im not made of money so i can't get it all done at the same time. heres a simplified list
1. Shocks replace
2. Drive belt replaced
3. Differential service (fluid change, filter change)
4. Plugs replaced (double platinum???im not sure what they are right now)
5. Find and kill the illusive noise coming from the front of the car. (my mechanic says either way that i should just listen and see if it changes in pitch, or gets louder before i take it back to find exactly where the noise is coming from)
I was thinking shocks first becuase i can do that by myself on a sunday afternoon, they're shocks all around on a 97 XLT right? The drive belt i thought should be second, then the differential service and plugs replaced.
I will have all this done regardless in about two to three months (if i still have a job
) so its not like ill put off any of this for a year which i know could cause some serious problems.
Thanks everyone,
Colin.
1. Shocks replace
Thanks everyone,
Colin.
