clawhn1
- June 6, 2009
- Katy TX
- 99 v8 and 93 xlt
hi, v6 93 ex, 4.0 2wd automatic tranny
i just spent 2,000 last week on a rebuilt tranny, they say they installed a "shift kit" and new solenoids and clutches
what happend was my mass air flow shorted out and it screwed up my tranny since its electronically controlled, i heared a loud clank when it happened and BAD rumbleling from 0-15 mph...it also started about 3 months ago when i cleaned for the first time my maf sensor and the harness and i forgot to unplug battery and might have shorted something...it ran with a loud roar every time you excelerated
well, they say they installed a new pcm computer saying my old one shorted out, installed a new maf, and rebuilt tranny
from 30-80 mph it runs great
but from 0-20 its slow as hell , i mean real slow, the guy even test drove it with me and i asked him why its doing this and he says its the passing gear and downshift and its normal for the shift kit
heres what it does, when your at 0mph and hit the gas , it takes about 1 second to go, usually it would go automatically when you hit the gas
at 15mph, and holding the pedal steady at 1500 rpm, the rpms jump drastically on its own to 2500 without increasing pedal and it does this before it shifts into 2nd gear...once it shifts into 2nd gear the rpms go back down to 1500.....he says this is normal????.and btw, it STILL roars !!!!
what is this? is this a slow oem mass air flow sensor he installed? the new pcm? or a bad first gear?
its automatic tranny
i dont know much about trannys,there are no hold shifts, or noises, this is the only problem
it also seems to do this a little bit when it shifts into every gear but the first-second shift i notice it alot because the engine roars real loud when it does this shift
ive had the car for 10 years, i rebuilt the tranny 5 years ago and it didnt do this...usually it shifted quietly and smoothy without even noticing
should i switch to my old granatelli hi flow maf? should i install 373 gear differential or is this the tranny?
even though its on warranty he WONT look at it...hes a dick, he swears its normal, but it sounds bad...sometimes it will do this and not even go into second gear unless i gun the trottle
now, if i excelerate hard,at around 2000 rpm, it shifts into 2nd gear smoothly without this problem, but when i hold it steady at 1500 it will jump on its own to 2500 in order to switch to 2nd gear.....what is this?
im thinking about taking it to another tranny shop and rebuild it again for 2000? should i?
