upther
- February 3, 2014
- Micco, FL
- 2004 Explorer Sport Trac
I'm kind of stuck here since I've gone through all the normal culprits.
When the truck is running and the headlights are on, they pulse. The longer it sits idling, the more they turn into a flash. They never go completely off, they just sit there and flash. The interior lights will do the same thing. Once I start driving, everything seems fine. Until I stop and the pulsing starts up again. If I turn the key to on without starting the truck, the lights and everything work just fine. No flashing or pulsing. Leads me to believe the battery is fine.
I took my volt meter out and checked the battery anyway and it was fine. I went to Advanced Auto and had them check the electrical system. The only problem they noticed was that the starter voltage seemed a bit low.
I'm going to replace the elbow that causes everybody problems, I do have some occasional rough idle, but I'm not sure if that has anything to do with the electrical issues. I took a look at it and don't see any cracks but obviously can't see under neath it.
Any thoughts?
Any thoughts?
