expatexplorer
- November 6, 2013
- 2005 explorer
I have a 2005 V6 4.0L Ford Explorer.
I am experiencing a rough idle issue that is proving hard to debug. Apart from a rough and stumbling idle, you can also detect that the car seems to miss slightly when cruising and hold a steady speed at 100-110kph.
When you accelerate from idle, it seems to have this flat spot at 1000rpm where it feels like the motor has been switched off, then picks up at again at around 1200rpm. It is like somebody has turned the key off.
The other interesting symptom is that I can slowly build up to revs from idle to about 1000rpm, then it drops to 900rpm and creeps back to 1000rpm. It oscillates between 900-1000rpm all day if you hold it there.
I have had the car back to the dealer many times. They tell me that it throws no codes and the scanner reports that all sensors are ok. They have given it a tune up and replaced many things including the harmonic balancer.
When I pick the car up, it runs fine for a short time then reverts back to its old ways, I guess this is the PCM module relearning problem.
To me it sounds like it might be a fault with the TPS or the throttle body, perhaps it has a flat spot on the TPS sensor that is not picked up in any error code. It feels like an electrical issue as it runs perfectly otherwise and the fuel consumption is pretty good. Has anybody come across this problem before? I think the dealership have run out of ideas, if I need to throw parts at it, I want to be throwing the correct parts.
