JCUZ
- September 4, 2007
- Canberra, Australia
- 2004 Explorer Limited V8
Just wondering if you can give some more info on this. mine is the same, fog lights only come on with high beams. I want mine wired back to the original switch, ie the pull out button on the headlight switch. Can you give me some info on this?
Thanks,
Hi, I installed a separate switch since mine doesn't have the pullout option on my headlight switch. I just cut the wiring at the foggies and ran my own wiring using a normal relay etc.
