How can i wire my KC lights to my fog lights but use them with high beams? Now with fogs on an i use high beams fogs go off? Anyone have a diagram or a easy way around?
Hmm after lurking around on the internet i found that it is illegal in PA to have fogs / highbeams on.. I am going to have to see if i can find if that is actually true before i go trying to change it
Wire them in with your fog lights and then mod your fog light relay. It will keep your fogs on even if your high beams are on. To the left of the motor you should see a box of relays. I can't remember the number for the fogs but it will be in your manual. Pull it out and break off one of the tabs on the side with three on it. You'll want to break one of the end ones,not the middle one.
Where at in Pa. are you? I'm in Pittsburgh. There's plenty of write-ups on hiw to do the high beam/foglight mod, in Pa. you can only have one set of fog/driving lights on with you low or high beams on. Nothing above the hood (fog/driving lights) can be on while driving on roadways except for plow trucks.
Yep, all shops are different depending on how much of a dick the person doing the inspection is. If they went buy the "law then there wouldn't be any vehicles pass Pa. inspection. From the Penn D.O.T. Law, "Anything other then factory O.E.M. parts will disqualify a vehicle from passing Pa. state safety inspection".
#3 goes to the ground to the relay for the fogs
#5 i tapped into the #5 on the other switch
#6 I tapped the output 12v signal to the fogs right off the relay to save wire.
I got this relay 30 went right to the lights an number 6 prong on second fog light switch 85 went to ground 86 went to number 3 prong on the second fog switch an 87 went to power
But the lights stay on is there something i am missing ?
