Ford Explorer 2009 Rough Idle and Engine Stall when warm - PLEASE HELP | Ford Explorer Forums
Abraham DXB
UAE
Ford Explorer 2009 XLT 4L
I have a Ford Explorer 2009 model based in United Arab Emirates, It has 230K KMS on the odometer.
Recently i have noticed the following;
1. Only After the engine warms up it has a rough idle and sometimes stops in the traffic signal.
2. There is no Engine Error Light coming on but on checking using the OBD Scanner i see the below codes.
P0135 O2 Sensor Heater Circuit Bank 1 Sensor 1
P0141 O2 Sensor Heater Circuit Bank 1 Sensor 2
P0155 O2 Sensor Heater Circuit Bank 2 Sensor 1
P0161 O2 Sensor Heater Circuit Bank 2 Sensor 2
P0403 Exhaust Gas Recirculation Control Circuit
P0443 Evaporative Emission System Purge Control Valve Circuit
3. Replaced all Spark Plugs checked wires and connectors but all seems fine.
4. I have replaced the EGR, although the rough idle is mildly better it still has issues
Any thoughts or suggestions, KINDLY HELP PLEASE.
